Алуминиеви греди Menabo от Lidl
...Здравейте колеги. Някой има ли (чувал ли е) мнение за напречните Алуминиеви греди от Lidl. Поразрових се малко и до колкото разбрах са Този модел MENABO BRIO  , което не звучи чак толкова зле за въпросната цена. Прочетох доста добри мнения за цена/качество на тези греди и все пак искам да чуя мнения от първа ръка - шумят много(при каква скорост), стават/нестават на Октавия 2, удобни/неудобни за слагане/сваляне и т.н. Казват, че не са не нивото на Туле, но и няма как като са и под 1/3-1/5 от цената ;)
Благодаря Ви предварително.
П.С> А ето и няколко мнения, които намерих из Интернет, почти не видях отрицателни мнениея:
They come ready assembled, and there is no need to do anything other than read the instructions on how to fit them.
One side is moveable and slides up and down the bar, the other is fixed.
You place the fixed end on on side bar, and then turn the allen key (supplied) in the hole to slide the other side to fit the bar on the other side. And then tighten it to fit....that simple.
You can place them at any position on the Dusters fitted roof bars. Front, middle rear, or inbetween depending on what you are moving.
They don't "perfectly" fit the profile of the bar, only the Dacia ones will do that....but they do go all the way round and fit it like a clamp...and then you tighten them...and then they don't budge.
Its as if they designed them for the Duster really, they are really good......
Once you are happy with them....you lock them with a proper key and everything ...YAY
Oh and with rope and some serious knotts.....transported a 6x6 fence panel over 25 miles and over the Forth Road Bridge.
As pictured.
They are superb, and I'm sure will pretty much carry everything you need.
Hope this helps folks
Alloy aero roof bars at Lidl , to fit cars with exsiting roof rails ie most estates. Just bought a pair, fitted/tested them and they're fantastic for the money. Made by Menabo.
I bought these last time Lidl had them and am well impressed with the quality.
Size wise, they are tested on a 2005 Jaguar X type estate, VW Passat 2001 estate, 2006 Landrover Freelander. They didn't fit a Mercedes ML320 as they weren't wide enough.
The quality is pretty good on these and marvellous for the money. I've got a Thule roof box and bars and the Thule bars aren't really that much better than these Lidl (Brio branded) items - great value for money.
Петко, гредите са качествени и изключително здрави и идиотоустойчиви.
Цената също е страхотна.
Препоръчвам с две ръце.
...Благодаря Боре  :cheers:  аами то като гледам със сигурност ще се ходи до Лилд, че си харесах и 2бр "Подложка за детска седалка за автомобил" . Сигурен съм, че подложките от СуперШкода са по-добри но и почти 3 пъти по-скъпи (а на външен вид са същите). А за Лидълските  греди чувам все повече положителни мнения, а и ние няма да ги ползвам чааак толкова често. Но пък и чакам един отговор и ако не е положителен до понеделник-вторник май ще скачам не тези.
btw Мисля, че съм виждал и багажници за колела за покрив на Лилд ....нищо чудно скоро да питам и за тях ;).
...Това е добре, ще се оглеждаме за тях.
Един познат каза като забележка за  Лидълските, че "Гредите са шумни", какво точно има предвид и при каква скорост - още чакам да ми отговори. Някой да е чувал за такъв проблем ?
Една интересна тема :)
Тъкмо и аз се бях загледал в конкретните греди и проявих интерес към тях.
Преди време се поразрових из нета за такива неща и цените им са от 180лв нагоре, дори и 2-ра ръка.
Относно тези в Лидл май трябва да имаш надлъжни греди на тавана, демек да си комби, за да ги ползваш. Поради този факт аз май няма да мога да се класирам :(
Иначе вчера познат  ми каза, че на времето е карал с подобни греди и ме посъветва ако си взимам да са алуминиеви + да са заоблени от горе /да не са с ръбове защото много свирят/.
Имам такива греди от предишните промоции и наистина са млако шумни - свирят над 7-80 не не е непоносимо, иначе изглеждат здрави и за сега и няма проблеми.
За около година съм ги ползвал поне 10ина пъти и са си добре за цената.
Гредите се маунтват добре и на ОК1, макар, че не зная защо в списъка отзад на кутията липсва модела. Може би, защото са по-тънки надлъжните рейки или профилът им не е толкова "подходящ" за гредите.
За свиренето проверете дали сте сложили уплътненията отдолу. Свиренето идва точно от там.
За какви уплътнения отдолу говориш, колега? Това, което виждам, са пласмасови "капачета" на лапите, които не падат, а са закрепени добре. Има ли нещо допълнително, което да се слага? Поздрави.
На долната страна също има улей, в който се движи лапата. От него идва цялото свирене.
 ...Това поне е лесно да се провери. Едва ли има оригинални уплътнения, но спокойно може да се пробва с едно тиксо пък ако верно спре да свири да се търсят по-кардинални решения ;)
А иначе наистина ходих до Lidl и дори взех един комплект греди и 2 подложки за седалки, но гредите бяха за един съсед (дори му помогнах за монтажа). Просто колегата Bucket  ми направи оферта на която не можах да откажа и се сдобих с оригинални за О2  ;)
...Лидълските ги монтирахме на един пасат Б4 комби. Паснаха перфектно. Определено изглеждат доста прилично за цената си, а Пасата ще участва дейно в строителски работи на една къща, така че може след време да споделя как е след сериозно натоварване.
За оригиналните не мога да кажа нищо лошо, защото аз по-скоро търсих недостатъци -предимствата са ясни. Та единственото което намерих е, че и те Свирят само че при скорост около 120. Със сигурност ще пробвам това със запушването на улея отдолу като ги сложа следващия път.
Благодаря много за споделените мненията. На мен лично ми бяха доста полезни, надявам се да помогне при избора и на други колеги  :cheers:
Тъкмо щях да питам дали стават на О1, че днес ги гледах и изглеждаха прилични, но не пише, че са подходящи за О1.
Чудесни са за О1 :)
Дали някой е видял дали стават за С3 ? Че определено ще ми трябват, а не намерих описание никъде.
C3 ?!?
Ситроен С3 (да се чете "Цъ Три") - в тоя форум сме шкодаджиЙ - тоест, С3 = Супърб 3, не Стара Загора :D (бъзикам се)
Редактирано от shaft
Джуджииии, и теб те е прихванало, заболяването на Сашето - "Шкодаджии", какви "ШкодаджиЙ" сънуваш ...
Пустият му контупер, с LAN интернат и фрашка... :)
Нали сега е модерно, 'жужи! Затова така го написах, да мА разбере масата народ, че иначе ще си кажат "тоя дебил го е написал верно и не мога да го прочета"... и реших да съм с крак в ръка срещу времето :D се'еш ли се? Или не се сееш.
Ахаха... и сега ми хрумна още нещо - като излезе Супърб 4, който напише С4... едва ли ще говори за експлозиви :D
Жужетоо, признавам тЪ !!!
Ама, понеже, защото - абе, измръзна ми с тез дИца, а тука е като Жунгла, та за туй...
П.С. Някой, да ни разчисти глупостИтИ, моля!
Моля, да бъда извинен за лошото качество. Пропуснал съм, че Пепи е обновил автопарка!
Редактирано от 4е4о
Купих си. На кутията пише само за Superb 3T, което е 2ка фейслифт. Но пробвах и стават и за 3ката комби. Това което не ми хареса е, че отдолу гредата е отворена и със сигурност ще шуми. Но за целта ще се намери подходяща гума и ще се разреши проблема. Мисля, че си реших проблема с багажника за ски  :hockey:
И аз си взех и съм доволен, засега нямам какво да кача отгоре, но скоро мисля да сложа байковете за някаква кратка разходка. Гредите изглеждат доста прилично.
https://goo.gl/photos/1GdMiNCvCEjP3rCbA
Аз само ги пробвах и ги махнах. Не виждам никакъв смисъл да ги търкалям просто ей така.
е и аз няма да ги оставя во веки веков на колата. пък и като гледам ключа, ще трябва да ги сваля аз, да не ги свали някой друг :crazy:
