O2_O2Face_Scout Мулти-Волан Адаптация. Г85
Bsea
здравейте понеже слагах на О2 Префейс Скаут Мулти волан от Фейслифта и модула под волана.
Както винаги изчезва хидравликата независимо как го слагаш при разкачен акумолатор или не винаги е едно и също. иска си адаптация на стийринг ъгъл сензора G85 и тракшъна.
с 2 различни модула го правих и на 2та стана с малко повече мъка 2часа и малко.
Стъпка 1:
Basic Setting Sensor for Steering Angle (G85)
Important Note: This procedure ONLY applies to Models with Conti/Teves MK70 ABS/ASR.
This Procedure does NOT apply to Conti/Teves MK60, MK60CE, MK60EC1 and similar ABS/ASR/ESP systems. Check the Vehicle specific Diagnostic Procedures pages for each ABS System page with documentation.
EXCEPTION: It may be necessary to perform this procedure (in addition to the corresponding one in the ABS itself) if the ABS coding has been lost or the ABS module has been replaced.
Prerequisites:
  • Start the vehicle.
  • Turn the steering wheel one turn to the right and one turn to the left.
  • Drive in a short distance straight line on a level surface at a speed not higher than 20 km/h.
  • If the steering wheel is straight during the test drive then stop the vehicle with the wheels pointed straight.
  • Ensure that the steering wheel is not moved again.
  • Keep the engine running and do not switch off the ignition.
  • System voltage at least 12.0 V.
[select]
[44 - Steering Assist]
[Coding-II - 11] or if that function is not available then use [sec.Access - 16] instead
Enter 40168, to enable the basic setting.
[Do it!]
[basic Settings - 04]
Group 060
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
After a successful basic setting, field 1 should say "OK".
[Done, Go Back]
To make sure the basic setting was successful, check the sensor again.
[Measuring Blocks - 08]
Group 007
[Go!]
Check field 1, the value has to be between -1.5 and +1.5 °.
[Done, Go Back]
[Close Controller, Go Back - 06]
Стъпка 2:
Checking Steering Torque Sensor (G269)
Prerequisites:
  • Ignition ON
  • Engine ON (Idle)
  • System voltage at least 11.0 V.
[select]
[Meas. Blocks - 08]
Group 001
[Go!]
Field 2: Steering Torque Sensor (G269)
Turn the Steering Wheel multiple times completely to the left and right. The Torque Values should change.
If the Torque Values do change, it's most likely an intermittent Fault in the Wiring/Connectors.
If the Torque Values do NOT change, the Sensor itself or the Power Supply (Terminal 15) might be faulty.
Group 004
[Go!]
Field 2: Power Supply (Terminal 15), Specification: "Term. 15 ON"
[Done, Go Back]
това е което можете да следвате и почти винаги работи на 3 волана съм го правил единият е моя. Надявам се на някой да му е от помощт.
