Съкращения използвани при автомобилите
vRS
ABC - Active Body Control
ABS - Anti Blokier System
AC - Air Condition
ACC - Active Cruise Control
AGS - Adaptive Gearbox Shift
ALB - Anti Lock Braking
ASC - Automatic Stability Control
ASC+T - Automatic Stability and Traction Control
ASMS- Automatic Stability Management System
ASR- Anti Schlupf Regelung
ATM -Adaptive Transmission Management
AUC -Automatische Umluft Control
AWD- All Wheel Drive
BAS -Brake Assyst
BST -Battery Safety Terminal
CAN- Controller Area Network
CDI - Common-rail Diesel Injection
CFI -Central Fuel Injection
CNG -Compressed Natural Gas
CVT- Continously Variable Transmission
DBC -Dynamic Brake Control
dCi -diesel Commonrail injection (Renault)
DDE -Digital Diesel Electronics
DISA -Differenzierte Sauganlage sistem
DOHC- Double Over Head Camshaft
DME- Digital Motor Electronics
DSA -Dynamic Stability Assistance
DSC -Dynamic Stability Control
DSTC- Dynamic Stability & Traction Control
dTi ..-dizel Turbo intercooler
DTI -Dizel Turbo Intercooler
EBD -Electronic Brakeforce Distribution
EBV- Elektronische Bremskraft Verteilung
ECU-Engine Control Unit
EDC -Electronic Damper Control
EDC -Electronic Diesel Control
EDS -Elektronische Differencialsperre
EFI- Electronic Fuel Injection
EG- European Gas
EGR- Exhaust Gas
EMC -ElectroMagnetic Compatibility
EPS -Electronic Power Steering
ESP -Electronic Stability Program
ETC -Electronic Traction Control
ETS- Electronic Tracion System
EV -Electric Vehicle
FDR- Fahr Dynamik Regelung
FFV- Flexible Fuel Vehicle
FIRE -Fully Integrated Robotized Engine
F.I.R.S.T.- Fully Integrated Road Safety Technology
FPS -Fire Protecting System
GDI- Gasoline Direct Injection (Mitsubishi)
GPS -Global Positioning System
HDC- Hill Descent Control
HDi .- High-pressure Direct Injection
HP -Horse Power
HPi -... ... injection
i, I- Injection
IC- Inflatable Curtain
ICIM -Individual Control Intake Mainfold
IMS- Instant Mobility System
IRD -Intermediate Reduction Drive
ISOFIX -International Standard Organization FIX
ITS -Inflatable Tubular Structure
JTD- uniJet Turbo Diesel
KW- Kilowatt
LSD -Limited Slip Differential
MPI- Multi Point Injection
NGV- Natural Gas Vehicle
OBD- On Board Diagnostic
PDC- Park Distance Control
PES -Poli Elipsoid System
PPD- Passenger Presence Detection
PRS- Programmed Restraint System
SIPS -Side Impact Protection System
SDI- Standard Diesel Injection
SMH- Societe de Microelectronique et d'Horlogerie
SOHC- Single Over HeadCamshaft
SPI -Single Point Injection
SRS -Supplemental Restraint System
STC -Stability & Traction Control
TC -Traction Control
TCS- Traction Control System
TDI- Turbo Diesel
VANOS- Variable Nockenwelle Steuerung
VDC -Vehicle Dynamic Control
VIS -Variable Induction System
VTEC- Variable valve Timing and lift Electronic Control system
VVT-i Variable Valve Timing - intelligent
WHIPS -WHiplash Protection System
WET W- Engineered Tread
4WD - Four Wheel Drive
4WS - Four Wheel Steering
Ако се сетите за друго съкращение го добавете тук :-k
Струва ми се че TDI идва от Turbo charged Direct Injection - Директно впръскване с турбо нагнетяване или нещо такова - ако има ДВГ инжинер да ме поправи.
И още едно съкращение се сещам в тази връзка - VTG - Variable Turbine Geometry - Турбина с променлива геометрия на лопатките - служи за смекчаване на ефекта на турбо дупката.
... и още няколко свързаи със Шкода:
TDI-PD - TDI - Попмпа-дюза
FSI - direct fuel injection
TMPI - Turbo charged multipoint injection
HTP - High Torque Performance
DSG - Direct shift gear - автоматична ск. кутия с възможност за ръчно превключване на предавките
TPM - Tyre pressure monitoring
MSR – Torque Moment Regulation
HBA – Hydraulic Braking Assistant
  • 5 месеци по-късно...
MBA (Механичен Спирачен Асистент)
EDL (заменя раздатъчната кутия), ама това какво ще рече моля да обясни някой друг :roll:
FSI - fuel stratified injection
DSG - Direct shift gearbox
  • 7 месеци по-късно...
The electronic differential lock (EDL) permits smooth, comfortable starts on road surfaces that do not have a uniform coefficient of friction. If a wheel starts to spin, EDL brakes it as necessary so that power is transmitted to the wheel with the better traction. EDL reduces tire wear and works up to about 25 mph (quattro®: up to about 50 mph). EDL is part of the Electronic Stabilization Program (ESP) and the traction control (ASR) .
С други думи превърти ли колело EDL-a му натиска спирачката и така въртящия момент се предава на другото колело.
МАЗ-Мамо аз загивам! :lol:
АЗЛК-Ах защо ли те купих! 8)
(нищо лично към притежателите на Москвич-просто шегичка)
предлагам тая тема да се сложи отгоре, че който накога се зачуди за някое съкращение да му е под ръка :idea:
П.П>
АЗЛК - Ах, Защо Ли те Купих?
ЗАЗ - Завод Автомомобильних Зверей
БКП = Бегай Керемидите Падат
имаше и едно готино сайтче със значенията на съкращенията на западните марки в същия дух, ама не пазя линка... помня само за Buick беше нещо от сорта на Big Ugly I... Car
П.П. 2 между другото въпрос за 100 х. лв. от Стани богат - какво означава съкращението MG? ха да ви видя сега! ;)
Morris Garages 8) Айде, колега снеси сега 100 бона :lol: ! :P
