I'll ask here also maybe some one knows the answer. It is about some U pieces, coming at upper arm at front axle. Theyr role is to adjust a distance for right angle of the wheel. Now my problem is how I could choose the right combination of those U pieces for right adjustment. Thnx
Hi, the vertical angle adjustment of the front wheel can be only done by turning the excentric bolts comming throgh the lower arm. Is this what you mean?
No. There are some pieces which have a "U" shape which comes between uper arm and the body of front axle. Tiny litle pieces I'll make a picture for better understanding.
Ok, understood!
So, what you have to do is to defix the u-pieces from the originally fitted front body and to fix them on the new one. Those u-pulleys are fixed in the factory when the deviation due to the welding of the body is determined.
Aha. Understand now. Thnx a lot.
off topic: I always forgot. Nice car you have. It's original GLS?
