VAG-COM Version: Release  311.2-N
Chassis Type: 6Y - Skoda Fabia
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 01     -------------------------------------------------------
  Controller: 038 906 019 CN
  Component: 1,9l R4 EDC 0000SG  1358
  Coding: 00002
  Shop #: WSC 13765
No fault code found.
Address 08     -------------------------------------------------------
  Controller: 6Y0 820 045
  Component: Klimaanlage        X0830
4 Faults Found:
01596 - Motor for Outside/Recirculated Air Flap (V154)
           30-10 - Open or Short to B+ - Intermittent
           29-10 - Short to Ground - Intermittent
           28-10 - Short to B+ - Intermittent
           55-00 - Adaptation Not Successful
Address 09     -------------------------------------------------------
  Controller: 6Q1 937 049 B
  Component: BORDNETZ-SG.        1S31
  Coding: 25754
  Shop #: WSC 13765
1 Fault Found:
01598 - Drive Battery Voltage
           07-10 - Signal to Low - Intermittent
Skipping Address 15-Airbags
Address 17     -------------------------------------------------------
  Controller: 6Y1 919 870 D
  Component: KOMBIINSTRUMENT VDO V11
  Coding: 20141
  Shop #: WSC 05201
  TMBGS46Y323512723
Address 19     -------------------------------------------------------
  Controller:  6N0909901
  Component: Gateway K<->CAN    1S31
  Coding: 00012
  Shop #: WSC 13765
Address 44     -------------------------------------------------------
  Controller: 6Q0 423 156 K
  Component: LenkhilfeKYO        X908
  Coding: 00110
  Shop #: WSC 13765
Address 46     -------------------------------------------------------
  Controller: 6Q0 959 433 E
  Component: 2S Komfortgerat     0001
  Coding: 00067
  Shop #: WSC 13765
1 Fault Found:
01033 - Central Locking Key Switch: Passenger Side: Unlock
           27-10 - Implausible Signal - Intermittent
End   -------------------------------------------------------
Как да разбера кое какво означава? Има ли някъде възможните грешки ?
До колкото разбирам грешките ми са 3.
В клапата на парното/климатика
Някаква батерия????
И в дясната врата????
Митаче, да почна аз малко отзад напред.
intermittent-прекъсващ (се), пресеклив, пулсиращ, скокообразен, ел. прекъснат, пулсиращ, импулсен (за ток)
implausible- неправдоподобен, невероятен, неприемлив
Следователно:Central Locking Key Switch: Passenger Side: Unlock
Централен заключващ превключвател (прекъсвач:комутатор) : Пасажерска страна- отключена
Implausible Signal - Intermittent: (неправдоподобен, невероятен, неприемлив) сигнал- intermittent-горе виж значенията.
Думата Drive има много значения-според мен тук е :
Волтаж Управляваща Батерия (демек акумулатор :) )
Сигнал прекалено нисък (слаб) - за intermittent пак виж значенията.
4 Faults Found:
Не мога дословно да го преведа.
Мисля,че показва грешка за двигателчето (моторче) за рециркулация в купето (Flap-мисля,че е клапа?)
Първите 3 грешки са може би за + са или 0(явно нещо свъръзката не може да се хване)
Ама не съм много сигурен.
Последното пише,че адаптацията е неуспешна.
Митаче,поздрави и успех.
И аз така си ги превеждам, но на дясната врата й няма нищо от към заключване, освен копчето за стъклото което няма 2 степени. До колкото тази батерия се сещам единствено за акумулатора, който си е ОК. Да има някоя батерия за часовник например? Не ми се вярва нещо... :-k
За клапата ясно - ще трябва да сменям мотора.
Митак,
Под "батерия" имат предвид акумулатора. Ако е паднал и се опиташ да запалиш сваля напрежението под 9 волта (нищо, че си пали уж без проблем) и вдига аларма по разните електроники.
За вратата - най-вероятно датчика се е прецакал и непрекъснато показва отворено или затворено ...
Този отговор чаках. :smt017
Мерси!
А освен този датчик за отворена/затворена врата, какви са другите възможности? Защото осветлението се пали от нея и се загася без видими проблеми. Стъклото също. Може би датчика който отчида дали е заключена/отключена.
П.п Всъщност да не си "чеша" пръстите ами да я отварям и да видя :lol::lol::lol:
На мен Drive Battery Voltage ми звучи като Напрежение на акумулатора в движение.
погледни колко зарежда на ниски и средни об.
С вагкома показва 13.9V на празни и на средни обороти. С мултицет директно на акумулатора не съм мерил.
Може би при паленето му пада напрежението от голямата консумация...
Днес като отключих с дистанционното на ключа след около 3-4 секунди вратите почнаха да се отключват сами(както си бяха отключени) и стъклата се свалиха. Имах чувството, че бутона на дистанционното е блокирал в натиснато положение но не беше... Тогава се сетих за този проблем :
  Coding: 00067
  Shop #: WSC 13765
1 Fault Found:
Дали това е модула за отклучване/заключване на дясната вратата? Т.е тя може ли да кара останалите врати да се отварят ако е блокирало нещо в механизма?
