Здравейте! Забелязах, че като усиля парното или спускам продължително, температурата на охладителната течност драстично започва да пада. Имам съмнения за повреда в термостата! Имате ли мнения? Мога ли да се справя сам или да търся сервиз?
това е 100%
това е 100%
smile162
Колега по добре отиди в сервиз щом не знаеш дали ще се справиш. А и не си казал за кой мотор става дума.
Щом питаш дали можеш сам,явно не можеш отиди в сервиз,явно че е термостат
Не пишеш какъв е двигателя, но на 1,6 75 hp се сменя като детска игра.
Ето ти упътване, ти си реши.
Removing and installing, testing coolant thermostat
Special tools and workshop equipment required
- Torque wrench 5 to 50 Nm (e.g. -V.A.G 1331 -)
- Pliers for spring strap clips
Note: Always replace seals and gasket rings.
Removing
– Drain coolant → Chapter.
– Detach coolant hose from connection fitting -3-.
– Release bolts -4- with hinged wrench, remove connection fitting with “O”-ring -2- and thermostat -1-.
Testing coolant thermostat
– Heat up regulator in a water bath.
Start of opening End of opening Opening stroke
approx. 87°C approx. 102°C → Note min. 7 mm
1) cannot be tested
Install
– Clean sealing surface for “O”-ring.
– Insert coolant thermostat.
Fitting position: The clamp of the coolant thermostat must be positioned vertically.
– Moisten new “O”-ring with coolant additive.
– Tighten bolts to 15 Nm.
– Filling system with coolant → Anchor.
Draining and filling up coolant
Coolant capacity approx. 5.0 litres
- Catch pan (e.g. -V.A.G 1306-)
- antifreeze tester
Draining
WARNING
Hot steam may escape when the compensation bottle is opened. Cover the cap with a cloth and open carefully.
– Open the cap of the coolant expansion reservoir.
– Remove noise insulation in middle -arrows in top half of fig.-.
– Position drip tray (e.g. -V.A.G 1306-) under the engine.
– Turn the drain plug -arrow- on the radiator to the left and draw backwards, if necessary fit auxiliary hose onto connection.
– Also remove the front coolant hose on the oil cooler -arrow- and drain residual coolant.
Note: Collect drained coolant for proper disposal.
- Observe the disposal instructions for coolant.
Filling up
Select the appropriate coolant additive from the catalogue of original parts Škoda or from the list of allowed coolant additives → Octavia
Recommended mixture ratios:
Antifreeze protection down to Antifreeze concentration → Note2) Drinking water → Note
-25°C
-35°C 40% (2.8 ltr.)
50% (3.45 ltr.) 60% (4.1 ltr.)
50% (3.45 ltr.)
1) The proportion of coolant additive must not go below 30% due to corrosion protection considerations but must also not exceed 60% otherwise the frost protection effect will be reduced and the cooling effect worsened.
2) The coolant amount may differ according to the version of the vehicle.
– Fit coolant hose onto oil cooler.
– Screw in coolant drain screw.
– Fill up coolant gradually up to the “max” marking on the compensation bottle.
– Seal expansion reservoir.
– Start engine and run for not more than 3 minutes at about 2000 rpm.
– Run engine until fan starts.
WARNING
Hot steam may escape when the compensation bottle is opened. Cover the cap with cloths and open carefully.
– Check the level of coolant and top up if necessary. When engine is at operating temperature the coolant level must be at the “max” marking, when engine is cold between the “min” and “max” markings.
Благодаря за упътвянето, страшен си! Ще се справя с тази задача.
за 10-15лв струва ли си да се цапаш :-k
Ми то Търново до "Габрово"... smile049
smile091
С колко деления ти пада температурата в този студ е нормално да падне 1 2 деления на не добре загрял мотор. Загрява ли до 90 градуса като я караш нормално?
Споделям моя опит:
На мен смяна с нов + труд (от които 6 лв е приемчик) в ЕТ ми излезе смяната 67 лв с ДДС преди година и нещо. Може да е много ама си имам сега 2 години гаранция :smt017 .
Стария термостат като почна проблемите, сутрин по-бавно загряваше но в градско където се товари двигателя с тръгване-спиране държеше 90 градуса. Изляза ли обаче на магистрала и започне да се обдухва колата от вятъра - падаше до 1/3 от това.Спирането на парното съвсем леко оправяше проблема - и с парно и без парно с 90-100км/час двигателя направо изстиваше.
Сега новия работи с една идея малко по-студено. Стария точно цепеше чертичката за 90 градуса, с новия стрелката е в началото на чертичката без да я покрива.
Това проблем ли е?
Миналия месец смених моя ,защото при +8 градуса на въздуха,температурата падаше до под 60 градуса.Сложих на BEHR (28 лв.)и съм доволен.При минусови температури,каквито са сега, стрелката не мърда и милиметър от 90 градуса.
Същата работа. В събота малко навигирах с лаптопа. Вдигна максимум 70 градуса за 10-тина километра градско. Преди това ми изстиваше по надолнищата и стигаше почти до началната черта.
