при мен драмата с печката (PTC Heater 1K0 963 235 E) продължава. През почивните дни се хванах да я инсталирам. Монтирах я, свързах я към САN кабела (жълто-зелена на пин 1 и жълто-кафява на пин 2), доста форуми прегледах и навсякъде бяха тези цветове, прекарах кабелите към акумулатора, но след активирането й продължавам да не я откривам. Дава ми същите грешки като я нямаше:
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1Z0 907 044 AB    HW: 1Z0 907 044 AB
   Component: ClimatronicPQ35 120 0600
   Revision: 00120022    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 76E9F80101DC1C9
1 Fault Found:
00402 - Auxiliary Air Heater Element (Z35)
            004 - No Signal/Communication
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
   Component: Bordnetz-SG     H54 2202
   Revision: 00H54000    Serial number: 00000005478614
   Coding: 11000E011104140043110D000000000000097F073C00000C000000000000
   Shop #: WSC 73430 790 12345
   VCID: 71E3CB1D68B23B1
   Subsystem 1 - Part No: 1Z1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 210108 022  0601
   Coding: 00057271
   Shop #: WSC 73430
1 Fault Found:
00483 - Control Module for Auxiliary Air Heater
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 161
                    Mileage: 97558 km
                    Time Indication: 0
                    Date: 2005.09.13
                    Time: 31:63:63
             Freeze Frame:
                        ON
                    Voltage: 14.40 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 P    HW: 1K0 907 951
   Component: J533__Gateway   H16 0191
   Revision:   H16       Serial number: 2000K081110720
   Coding: E9807F160002021302
   Shop #: WSC 73430 790 00000
   VCID: 346D020957204E9
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 157
                    Mileage: 97558 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 02:03:26
Address 7D: Aux. Heat
Cannot be reached
Тествах дали стига ток до нея - ток има.
Активирах я по следният начин:
http://www.fixpicture.org/medias/1425547165_tmp_1.gif
http://www.fixpicture.org/medias/1425547197_tmp_2.gif
http://www.fixpicture.org/medias/1425547223_tmp_3.gif
Едната грешка е от тук, но няма почти никакви опции:
http://www.fixpicture.org/medias/1425546708_tmp_Capture44.gif
Дали модулите може да са несъвместими или трябва да направя още допълнителни настройки?
Димон говори за цъкане на релета под волана, а там нищо не съм пипал, това не е ли за печките 1K0 963 235 F или се има предвид тези за самото парно?
Моля за съвет.
Поздрави :)
  • Отговори 242
  • vvarbanov
    33
  • Цецо75
    24
  • turbobiit
    22
  • димон
    19
Според мен не си я закачил правилно към CAN-а или поне CAN Gateway-а не я вижда. Този нагревател е 7D,  а за него грешката ти е красноречива. На другото Auxiliary Heater Installed може да му махнеш отметката, то е савсем друго нещо. И виж дали като я махнеш другите грешки ще се изчистят.
Редактирано от vvarbanov
Ще пробвам довечера да махна едната отметка и може би някои грешки да изчезнат, но CAN Gateway-a защо не я вижда не мога да си обясня.
Не ти се отварят линковете, за да видя как си я активирал. ... но относно кабелите и аз ги вързах по същия начин:
1 пин - оранжево-зелен,   2 пин - оранжево-кафяв.
При мен тръгна без проблем. Не знам дали има значение, но при мен CAN gateway е с друг номер:
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 071110F1001661
Coding: 352302
Shop #: WSC 73430 790 00162
VCID: 30657B3563C6FE9891C
No fault code found.
Аз си мисля че проблема може и да е в печката. Щом му дава грешка че не може да достигне до нея, значи все пак CAN Gateway-а е възприел отметката да търси такъв елемент. Но защо грешката не е No signal/communication. Колега след като добави печката в CAN-а появи ли ти се прозорче 7D (трябва да е последно) когато влезнеш в модулите в VCDS програмката?
Днес когато се прибера от работа ще проверя в лог файла на VCDS  ( мисля , че съм го запазил ) каква грешка даваше само с отметка на 7D , но без закачен PTC
Махнах отметката от списъка за добавяне и изчезна и активирането на 7D, а и менюто. Активирах го от 09: Cent. Elect. и пак се появи менюто, до което така или иначе нямам достъп.  Грешките останаха същите с изключение на 19: CAN Gateway, там изчезнаха.
Преди да я инсталирам грешките бяха същите, няма разлика :(
Печката уж трябва да работи, но няма как да съм сигурен. Взех я от колега във форума, който ме уверяваше , че работи, но не знам как мога да я тествам. По принцип дефектите, които дават пак я засича компютъра, но с други грешки.
И аз се чудя дали може CAN Gateway-а да не я поддържа или тя съвсем е прецакана.
ПС: Как да кача снимки, че с конвертиране не стана, а явно и с тези линкове не работи.
Според мен CAN-а я поддържа, щом я има в списъка за добавяне. Можеш ли да я добавиш от списъка на CAN-a (7D), да не слагаш отметка в 09:Central Electric и да пуснеш един ауто скан за грешки и да го пуснеш тук да го видим.
Моята работи с CAN - 1K0 907 530 H, както и с 7N0 907 530.
Това са грешките , които ми даде при активиран 7D, без да е закачен PTC
VIN: TMBGE61Z9B8024253
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: Cannot be reached 1100
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 J    HW: 1K0 937 087 J
   Component: BCM PQ35  H   103 0615
   Revision: 00103 AD
   Coding: 40000AB8E05BB1C040080080110081E4437800AE526D81605C8540000040
   VCID: 387543158BB626D8D9C
   Subsystem 1 - Part No: 1Z1 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 03111  26  0601
   Coding: 00D7B7
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 211010 05  54  0403
   Coding: 0730ED
   Subsystem 3 - Part No: 1Z0 951 171
   Component: Innenraumuebe  008 5101
   Subsystem 4 - Part No: 1K8 951 605 A
   Component: LIN BACKUP HO  H11 9004
2 Faults Found:
01134 - Alarm Horn (H12)
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 4
                    Fault Frequency: 6
                    Reset counter: 75
                    Mileage: 148456 km
                    Time Indication: 0
                    Date: 2005.14.23
                    Time: 17:54:06
             Freeze Frame:
                        Term 15 Off
                    Voltage: 12.65 V
                        OFF
                        OFF
                        Term 50 Off
                        OFF
                        OFF
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 75
                    Mileage: 148641 km
                    Time Indication: 0
                    Date: 2006.14.01
                    Time: 18:50:51
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.25 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
   Coding: 352302
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 75
                    Mileage: 148641 km
                    Time Indication: 0
                    Date: 2006.14.01
                    Time: 18:50:54
Cannot be reached
End   ---------------------------------------------------------------------
По всичко личи, че май пак ще се отваря за да проверя отново връзката с CAN Gateway :(
само да вметна, наскоро установих, че когато съм натиснал бутона за насочване въздушния поток към средните отвори за въздуха ефекта от затоплянето на реотаните е почти моментален и въздуха е доста по-топъл.
поразрових се за въпросният CAN Gateway - 1K0 907 530 P дали има с 7D: Aux. Heat и намерих, но са на друга версия: J533__Gateway H15 0190, J533__Gateway H15 0183.  Моята е J533__Gateway H16 0191 и би трябвало да е по-нова и предполагам да я поддържа.
Скоро ще я отворя пак да проверя връзката с CAN Gateway, но искам да питам дали има как да тествам по някакъв начин самата печка ако пак не я открива.
Какъв тест мога да направя друг?
Поздрави :)
Проблемът не е в gateway- а. Моята кола е 2 години по-стара, а модула ми беше с Н накрая и си работеше с него.  Провери връзката с can-а. И малко глупав въпрос, но + и - нали си ги вързал коректно?
Уж всичко свързах правилно, но ще проверя отново :)
Днес проверих отново връзките и открих къде е бил проблема. Оказа се, че не съм пъхнал добре кабелчетата в буксата, която влиза в самата печка. Буксата трябва леко да се разтвори за да могат да влязат кабелите както трябва. Сега вече компютъра я открива без проблем и няма грешки :) Остана само да я пробвам дали топли :)
Поздрави :)
:eusa_clap:  Браво. Ще топли къде ще ходи, щом няма грешки.
Попрочетох темата за парното и тази екстра с бързото нагряване, но при моята не съм забелязал такова нещо. Зимата ми отнема много време докато загрея купето - 10-15 мин. работа на място или колкото да я отрина от снега, но това което пишете за 30 секунди и да почне да духа топло не ми се е случвало. Как мога да проверя дали и аз я имам тази екстра, тъй като моята е внос от Швейцария и би трябвало да са й сложили и на нея печка :)
За реотаните в антифриза също не знам дали имам, но знам че постоянно ми се губи антифриз и вече 3 майстори я гледат и казват, че всичко е наред, но през 3-4 месеца от макс ми пада нивото до мин и трябва да доливам...
Редактирано от sheftura
1.Ако наистина е щвейцарка трябва да имаш калорифер, но може да е италианка.
2.Реотани в антифриза нямаш .
3.За загубата на антифриз - пукната глава.
Кажи им много поздрави на тия майстори.
1.Книжката на колата е от сервиз на Шкода в Швейцария, а и на багажника отзад си имаше лепенка CH като я взех.
 Този калорифер може ли да е изключен от компютъра? Всъщност и таблото ми беше на немски, та ходих да ми го обърнат на английски, но това може и в автокъщата да са го пипнали, както и лепенката, но пък сервизната книжка?
2.За реотаните ОК.
3. Пукната глава на двигателя ли? Това ми звучи страшно!!! Е как не са я видяли тези "специалисти"? Впрочем освен антифриз ми гори и масло. Вчера долях 400 мл., а последно я напълниха ноември месец, защото сваляхме турбото, че почна да вие и го пращах в София за ремонт, като мислехме, че с това ще се оправи, но явно не е там проблема. За това време съм минал не повече от 2-3 000 км.
Относно главата на 2.0 TDI, има доста писано във форума, аз за маслото, този разход си е доста. Общо взето остави ги досегашните майстори, и иди да я погледне някои който е наясно с тези автомобили.
Можеш ли да ме насочиш къде да прочета за главата на 2.0TDI, че нешо не откривам темата?
  • 7 месеци по-късно...
Днес направих диагностика на колата (Голф 5 1.9 тди 2006г ) и ми излезе тази грешка:
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
   VCID: 2D5D8AB7E4113E6B985-8078
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
            014 - Defective
Прочетох темата и разбрах за какво става въпрос.Направих Output test-а,и нагревателя се пуска.
Heater Element for Auxiliary Heating: ON
ON voltage 13.80 V Curent 39.0 A Output (мени се между 450 и 520 W примерно)
Тъй като правих теста на отворена врата плафоните в колата светеха,и след пускането на теста плафоните започваха да премигват леко.Та въпроса ми е,дали и при мен проблема е само в разпояването на тези транзисторчета,или там каквото са? :)
Колеги този нагревател само при дизела ли го има аз съм с 1.6 mpi
