Здравейте колеги днес правихме диагностика на Октавията тъй като ми светна лампата на еърбега. След изчистване грешката пак се появява. Според мен проблема е в кабелите под седалката или в куплунга дето минава от купето към вратата, но разбира се искам да чия и други мнения. Прилагам и лога от диагностиката.
Забравих да кажа колата е Октавия 2.
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 016 BE HW: 028 101 194 7
Component: R4 1,9L EDC G000AG 7000
Revision: 12345678 Serial number: SKZ7Z0D2737906
Coding: 0000078
Shop #: WSC 73430 790 00000
VCID: 67D1389F066DD43BA29
1 Fault Found:
17058 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 - 000 - Electrical Fault
Freeze Frame:
RPM: 882 /min
Torque: 52.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 13.83 V
Bin. Bits: 00101100
Temperature: 8.1°C
Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 K HW: 1K0 909 605 K
Component: 02 AIRBAG VW8 024 0700
Revision: 07024000 Serial number: 00378D05A3NT
Coding: 0012338
VCID: 346B9FD3073B6FA3D7B
1 Fault Found:
01221 - Crash Sensor Side Airbag; Driver Side (G179)
008 - Implausible Signal - Intermittent - MIL ON
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 2700104A090EBA
Coding: 3F3F0740071302
VCID: 29557EA7D0F9224B74D
1 Fault Found:
00466 - Control Module for Steering Column Electronics (J527)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 203
Mileage: 168551 km
Time Indication: 0
Date: 2000.00.00
Time: 12:41:34
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 BL
Component: 01 KSG 0301
Coding: 98F802007F2D8505484F861004
Shop #: WSC 20256 264 17157
VCID: 7BF974EF6AE560DB561
Subsystem 5 - Part No: 1Z0 951 171
Component: Innenraumueberw.005 4801
Coding: 00000000
Shop #: WSC 00000
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Component: NGS n.mounted
1 Fault Found:
01134 - Alarm Horn (H12)
000 - -
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1Z0 035 161 A HW: 01. 01. 03
Component: Radio FO3 0008
Coding: 0000400
VCID: 2C5B87B3DF0B37638FB
1 Fault Found:
00856 - Radio Antenna
011 - Open Circuit - Intermittent
Address 76: Park Assist Labels: 1Z0-919-283.lbl
Part No SW: 1Z0 919 283 B HW: 1Z0 919 283 B
Component: Parkhilfe 4-Kan H04 0020
Coding: 0001001
VCID: 3D7DBAF73471AEEB285
1 Fault Found:
01548 - Sensor for Parking Aid; Rear Right (G206)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 197
Mileage: 168236 km
Time Indication: 0
Date: 2000.00.00
Time: 09:09:42
End ---------------------------------------------------------------------
Долу под седалката куплунга прави номера. Мисля, че и други колеги се бяха оплаквали от това.
изгорялата свещ я видя нали?
Миналата седмица разкарах въпросния куплунг и под двете седалки, запоих кабелите и изчистих грешката, не е светвала лампата повече. Ето линк с подробно описание: http://forums.vwvortex.com/showthread.php?2815467
Да и аз подозирах, че е нещо под седалката от кабелите и куплунга, защото реално се прояви грешката преди време, когато взех колата веднага след автомивка.
Какво мога да му направя на тоя куплунг имаш ли идея Цецо? Смисъл да го отворя и почистя там контактните повърхности или ?
Иначе за свеща видях :)
След нова година ще поръчвам и ще се сменя няма как.
Сега виждам, че при мен е записана различна грешка, може при тебе да е друг проблем:
Part No SW: 1K0 909 605 N HW: 1K0 909 605 N
Component: Q2 AIRBAG VW8 015 2100
Revision: 03015000 Serial number: 0038ED0MYWTQ
Coding: 0020786
VCID: 3771A8DF164D84BBF29
2 Faults Found:
01218 - Side Airbag Igniter; Passenger Side (N200)
001 - Upper Limit Exceeded - Intermittent - MIL ON
01217 - Side Airbag Igniter; Driver Side (N199)
Coding: 0020786
2 Faults Found:
Ми различна е грешката, но според мен проблема идва от същото място.
Това с запояването на кабелите и махането на тоя куплунг ли е единствения начин и бързо ли успя да се справиш в домашни условия?
Доста бях поровил из форумите, и аз се надявах че има по-малко драстичен начин, но навсякъде правят това. В британския форум на Шкода няколко колеги са постнали, че са им го оправили проблема гаранционно като са сменили цялото окабеляване с ново със същия модел куплунги и след няколко месеца пак същата грешка... Проблема май не е само на Шкода, а на всички коли на ВАГ между определени години, и в Ауди и Фолксваген форумите имат подобни теми. Иначе става лесно, двете седалки за час и половина два и с една биричка... Успех, дано да е същия проблем, че еърбеговете са си цифра.
Ми явно и аз ще мина на този вариант... ама понеже сега е по-студено...вместо биричка ще мина на греано вино :)))
Ами можеш да го поразгледаш. Като цяло според мен проблема не би трябвало да е в самия куплунг, а някъде на границата кабел-куплунг. Там има механично движение по време на движение на седалката. Самия куплунг мисля, че беше със закопчалка, едва ли се мандахерца свободно та да се прецакат клемите.
Интересно е какво го прецаква, защото мойта кола е на много километри, но не е прецакан (засега). Но може би не е мърдана много седалката...
И да го запоиш не е проблем, но пробвай да видиш какъв е проблема.
И аз минах през тоя филм със светещата лампа за еърбега. След появяването на проблема и посещението в ЕТ се оказа, че направо са ми изключили буксата с уговорката да запиша час някой ден и да направят така познатото ни запояване. Е да, ама реших да отида при мой познат, който от години ми оправя проблемите с електрониката когато съм имал такива. Оказа се, че пътя на кабела е бил нарушен и не е бил закопчан на правилните места под седалката и понеже системата е животоспасяваща веднага набива грешка, след като включихме буксата и закрепихме правилно кабела под седалката изчистихме грешката и повече не се е появявала. ;) Съветвам след като се направи процедурата по запояване (или кой каквото е решил да прави) и след изчистването на грешката да си поиграете с раздвижването на седалката напред - назад, поради това, че буксата и кабела се движат заедно със седалката. :) Поздрави и дано съм бил полезен.
Колеги октавията я караме така от 2008 със светеща лампа за аербег. В Добрич проверяваха какво ли не, накрая казаха, че проблема е в шофьорската врата, но баща ми не даде да я разглобят, защото пък можело да не е от там, а не знам си откъде и нещо не му вдъхна доверие всичкото казано и те така си я караме със светеща лампа вече 4 години.
В Добрич проверяваха какво ли не, накрая казаха, че проблема е в шофьорската врата...
Дали пък не е в задна дясна джанта проблема ? smile049 При какви хора сте ходили, забога ?
Сервиза на шкода в Добрич всички го знаят, заведохме колата и я получихме точно с тези думи от Галин той Искрен знае за кого говоря и така си я караме вече 4 години, като през това време е била няколко пъти за смяна на масла, филтри и накладки и така никой не се заинтересова да го оправи.
Здравей, при мен проблема беше в бега на волана - лош контакт при буксата. Тествах със съпротивление, 3.2 ома и грешката изчезна. После разтворих ламелите на буксата за по-добър контакт включих и лампата не е светила повече. Става въпрос за О1.
В сервиза на Шкода като че ли като не могат да разберат даден проблем откъде е и почват с гадаенето.В Пловдив са същата работа!
Като иде реч за вратата - не се чудете! И хайде да не намесваме иронично джантите. А откъде да се вземе сигнала за СТРАНИЧЕН удар???
Аз не разбирам много, но от това което виждам като грешка по логиката и аз си мисля, че е възможно да има нещо във вратите и кабелите и сензорите там, защото ето грешката е:
Side Airbag - аз мисля, че е нещо точно от страната на шофьора във вратата някой кабел и букса или каквото има там да дава грешката. Лошото е, че и в ЕураТек да ида няма да разберат нищо онея смотаняци там.
Не искам да обиждам, ама те го заслужават, защото последно като ходих там да ми сменят масло, филтри.... и след това като дигна 140 и почва яко да тропа нещо.... и като погледнах под колата... на кората бяха завъртели само 2 от 4-те болта... та... не знам просто къде да ида за да знам, че освен че ще си платя ще мога да разчитам на резултата.
По принцип системата има две слаби места (там където се гънат кабели). Датчика за страничен удар на врата, минава през маншона (жълта букса).
Другото е под седалката, кабела към самия бег. Така, че може и във врата да е проблема.
Провери и двете. Това е, без да си поиграеш няма как да разбереш. Съдейки по съобщението, проблема по-скоро е около вратата, но не бих се обзаложил, тия съобщения не винаги имат нашата логика.
Добрия вариант е да говорим за прекъсващ кабел. По-лошия за скапан конектор. Най-лошия - умрял датчик. Ама едва ли.
