Кар аудио усилвател Audison SRx2
skodko
Единствената му забележка е, че му няма декоративните капаци отстрани.
Ето характеристиките му:
POWER SUPPLY
Power supply voltage: . . . . . . . . . . . . 11 ÷ 15 VDC
Idling current: . . . . . . . . . . . . . . . . . . . . . . . . . 0.6 A
Idling current when off: . . . . . . . . . . . . . . 0.002 mA
Musical max consumption: . . . . . . . . . . . . . . . 15 A
AMPLIFIER STAGE
Distortion –THD (1 kHz; 4 Ohms): . . . . . . . . 0.05 %
Bandwidth (-3 dB): . . . . . . . . . . . . . . 4 Hz ÷ 50 kHz
S/N Ratio (A weighed @ 1 V): . . . . . . . . . . . . 95 dB
Damping factor (1 kHz, 4 Ohms): . . . . . . . . . . . 150
Pre In input sensitivity: . . . . . . . . . . . . . . . 0.2 ÷ 5V
Speakers In input sensitivity: . . . . . . . . . . 0.4 ÷ 10V
Pre In input impedance: . . . . . . . . . . . . . 15 kOhms
Speakers In input impedance: . . . . . . . . . 100 Ohms
LOAD IMPEDANCE:
- 2 Ch. . . . . . . . . . . . . . . . . . . . . . . . . . 4 - 2 Ohms
- 1 Ch. . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Ohms
NOMINAL OUTPUT POWER (RMS)
NP @ 12VDC; THD 0.3% 4 Ohms: . . . . . . 45W x 2
OUTPUT POWER (RMS) @ 13.8 VDC; THD 1%:
- 2 ch (4 Ohms) . . . . . . . . . . . . . . . . . . . . 65W x 2
- 2 ch (2 Ohms) . . . . . . . . . . . . . . . . . . . . . 85W x 2
- 1 ch (4 Ohms) . . . . . . . . . . . . . . . . . . . . 170W x 1
FILTERS/INPUTS
Inputs: . . . . . . . . . . . . . . . . . . Pre In / Speakers In
Filters: . . . . . . 12dB/Oct., bypass / hi-pass / lo-pass
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . (50÷220) Hz
OTHER FUNCTIONS
Remote IN: . . . . . . . . . . . . . . . 7 ÷ 15 VDC – 1 mA
Connections for VSR kit
for SUB remote volume: . . . . . . . . . . . . . optional kit
Fuse: . . . . . . . . . . . . . . . . . . . . . . . . . . blade, 20 A
Protection: . . . . . . . . . . . . . . . . temperature >85°C,
DC voltage, overload
Green-red LED indicators: . . . . . . . . . . . . on-safety
MAX SIZE (D x H x L): . . . . .178 x 49.5 x 210 mm
WEIGHT: . . . . . . . . . . . . . . . . . . . . . . . . . . .1.5 kg
345_zps526bb9c0.jpg Цена 80 лв.
За контакти: 0883452772 0893254555 Тодор. Намира се в Бургас.
