Проблем с Fabia 01 TDI PD
borko1912
Здравейте , от скоро чувам реле което отваря и затваря постоянно , което е много дразнещо , след преглед установих че е реле 8 с номер 53- номера е за универсално реле.. а 8 отговаря на low heating capacity...
след диагностика с ваг установих следните грешки:
VAG-COM Version: Release 409.1-US
Chassis Type: 6Y - Skoda Fabia
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 01: Engine
   Controller: 038 906 019 AF
   Component: 1,9l R4 EDC 0000SG  1110
   Coding: 00002
   Shop #: WSC 13765
   TMBHS46Y223288137     SKZ7Z0A0915162
4 Faults Found:
17978 - Engine Start Blocked by Immobilizer
            P1570 - 35-10 - - - Intermittent
17569 - Manifold Temp Sensor (G72): Open or Short to Plus
            P1161 - 35-10 - - - Intermittent
18043 - Powertrain Data Bus: Missing Message from A/C Controller
            P1635 - 35-00 - -
18045 - Powertrain Data Bus: Missing Message from Electric Load Controller
            P1637 - 35-00 - -
Readiness: N/A
Address 03: ABS Brakes
   Controller: 6Q0 907 379 D
   Component: ABS/ASR 5.7 FRONT   V00
   Coding: 00188
   Shop #: WSC 13765
No fault code found.
Address 08: Auto HVAC
   Controller: 6Y0 820 045
   Component: Klimaanlage        X0760
Address 09: Cent. Elect.
   Controller: 6Q1 937 049
   Component: BORDNETZ-SG.        1S30
   Coding: 09362
   Shop #: WSC 13765
5 Faults Found:
00903 - Fuse for Heated Outside Mirrors (S196)
            37-10 - Faulty - Intermittent
00906 - Horn (H1)
            28-10 - Short to B+ - Intermittent
00778 - Steering Angle Sensor (G85)
            49-00 - No Communications
01324 - Control Module for All Wheel Drive (J492)
01044 - Control Module Incorrectly Coded
            35-00 - -
Skipping Address 15-Airbags
Address 17: Instruments
   Controller: 6Y1 919 880 Du
   Component: KOMBIINSTRUMENT VDO V09
   Coding: 16141
   Shop #: WSC 20127
1 Fault Found:
01176 - Key
            07-10 - Signal too Low - Intermittent
Address 19: CAN Gateway
   Controller: 6N0 909 901
   Component: Gateway K<->CAN    1S30
   Coding: 00014
   Shop #: WSC 13765
3 Faults Found:
            35-00 - -
Address 44: Steering Assist
   Controller: 6Q0 423 156 G
   Component: Lenkhilfe           0004
   Coding: 00110
   Shop #: WSC 00000
Address 46: Central Conv.
   Controller: 6Q0 959 433 A
   Component: 04 Komfortgerat     0002
   Coding: 00067
   Shop #: WSC 13765
End   --------------------------------------------------------------------------------------------------
Видях че имам проблем с огледалата , но бушоните са здрави , пробвах да сменя това реле 53 с друго 53 , промяна няма цъка си на интервали като когато съм на фарове премигват очевидно , вижда се че напрежението ги събаря , преди не беше така...
Къде да търся проблема...
Благодаря!
Весели Празници!
