Hello dear friends,
I will like to present some pictures with the cars that i have .
After a long discussion with Peter that helped me with some advice regarding route ,services and some contacts i have decided  to make an account on your forum.
I don't know if this is the correct section where i should post this topic , so i will like to apologize in advance in case this is not the section dedicated for this .
This year i will transit your country with the white 130 LSE from Ruse --> Makaza whit the final destination Thassos in Greece .
So i owned  a Skoda 120 L from 1980 that is in my possession from 2008 .
The exterior of the car is pretty much stock and the only modification that the car has are the following :
Engine - Felicia 136 B stock engine
Suspension - Rapid articulated shaft system
Gearbox - 4 speed Garde 4.22 final ratio
Rims - ATS classic 4x130 5.5 j 185 55 15
Race seats and belts
post-224-0-02829300-1534260242_thumb.jpgpost-224-0-32429000-1534260248_thumb.jpgpost-224-0-17971000-1534260256_thumb.jpgpost-224-0-35314600-1534260262_thumb.jpgpost-224-0-37185300-1534260268_thumb.jpgpost-224-0-29012400-1534260276_thumb.jpgpost-224-0-12289600-1534260282_thumb.jpgpost-224-0-00321100-1534260295_thumb.jpgpost-224-0-35929000-1534260303_thumb.jpgpost-224-0-63713900-1534260316_thumb.jpgpost-224-0-99483300-1534260322_thumb.jpgpost-224-0-10582800-1534260331_thumb.jpgpost-224-0-36885400-1534260338_thumb.jpgpost-224-0-99979100-1534260344_thumb.jpgpost-224-0-37477900-1534260356_thumb.jpgpost-224-0-38616900-1534260362_thumb.jpgpost-224-0-05933100-1534260369_thumb.jpgpost-224-0-25191400-1534260375_thumb.jpgpost-224-0-11394400-1534260385_thumb.jpgpost-224-0-58061100-1534260394_thumb.jpgpost-224-0-35994500-1534260404_thumb.jpgpost-224-0-29750500-1534260529_thumb.jpgpost-224-0-94797900-1534260536_thumb.jpgpost-224-0-67604600-1534260543_thumb.jpgpost-224-0-57434000-1534260549_thumb.jpgpost-224-0-98957700-1534260555_thumb.jpgpost-224-0-65366700-1534260563_thumb.jpgpost-224-0-06684100-1534260570_thumb.jpgpost-224-0-43657200-1534260576_thumb.jpgpost-224-0-91998700-1534260582_thumb.jpgpost-224-0-93234400-1534260590_thumb.jpgpost-224-0-12434500-1534260598_thumb.jpgpost-224-0-03454400-1534260603_thumb.jpgpost-224-0-34332200-1534260609_thumb.jpg
From 2015 i have started a restoration project on a original Skoda Estelle two know as 130 LSE.
After the restoration the car has the following modifications :
Engine - Felicia 136 M stock engine
Rims - Ronal 4x130 5.5 J 165 70 13
The car has a factory gearbox of 5 speed with 3.9 ratio(rapid articulated shaft system )  and a sunroof . The other futures on the car are pretty basic for 130 model range.
post-224-0-75434500-1534261895_thumb.jpgpost-224-0-30168700-1534261912_thumb.jpgpost-224-0-20389600-1534261919_thumb.jpgpost-224-0-31090100-1534261925_thumb.jpgpost-224-0-21316500-1534261932_thumb.jpgpost-224-0-25111000-1534261940_thumb.jpgpost-224-0-84379700-1534261999_thumb.jpgpost-224-0-73896000-1534262006_thumb.jpgpost-224-0-11840300-1534262014_thumb.jpgpost-224-0-68128300-1534262022_thumb.jpgpost-224-0-66912900-1534262030_thumb.jpgpost-224-0-69019900-1534262040_thumb.jpgpost-224-0-43900400-1534262181_thumb.jpgpost-224-0-29343600-1534262188_thumb.jpgpost-224-0-82242500-1534262194_thumb.jpgpost-224-0-16861900-1534262201_thumb.jpgpost-224-0-16849900-1534262215_thumb.jpgpost-224-0-89465700-1534262221_thumb.jpgpost-224-0-54549100-1534262228_thumb.jpgpost-224-0-80684300-1534262234_thumb.jpgpost-224-0-91935200-1534262241_thumb.jpgpost-224-0-25796700-1534262248_thumb.jpgpost-224-0-12411300-1534262256_thumb.jpgpost-224-0-72505100-1534262263_thumb.jpgpost-224-0-47503100-1534262565_thumb.jpgpost-224-0-93564800-1534262571_thumb.jpgpost-224-0-12490400-1534262578_thumb.jpgpost-224-0-48606600-1534262583_thumb.jpgpost-224-0-85687700-1534262589_thumb.jpgpost-224-0-78689700-1534262597_thumb.jpgpost-224-0-25762100-1534262605_thumb.jpgpost-224-0-32589000-1534262614_thumb.jpgpost-224-0-56377400-1534262622_thumb.jpgpost-224-0-08641200-1534262628_thumb.jpgpost-224-0-47720900-1534262634_thumb.jpgpost-224-0-86841400-1534262643_thumb.jpgpost-224-0-99232700-1534263926_thumb.jpgpost-224-0-06351700-1534263934_thumb.jpgpost-224-0-20656300-1534263941_thumb.jpgpost-224-0-04777000-1534263947_thumb.jpgpost-224-0-98298000-1534263953_thumb.jpgpost-224-0-01204600-1534263965_thumb.jpgpost-224-0-37449500-1534263975_thumb.jpgpost-224-0-29215800-1534263982_thumb.jpgpost-224-0-14808400-1534263990_thumb.jpgpost-224-0-63574100-1534263996_thumb.jpgpost-224-0-30341400-1534264005_thumb.jpgpost-224-0-91240900-1534264010_thumb.jpgpost-224-0-41580000-1534264017_thumb.jpgpost-224-0-57219700-1534264034_thumb.jpgpost-224-0-94854700-1534264043_thumb.jpgpost-224-0-83187200-1534264053_thumb.jpgpost-224-0-06630400-1534264060_thumb.jpgpost-224-0-59787900-1534264067_thumb.jpgpost-224-0-74857300-1534264082_thumb.jpgpost-224-0-90430900-1534264088_thumb.jpgpost-224-0-00025100-1534264096_thumb.jpgpost-224-0-07323200-1534264106_thumb.jpgpost-224-0-92366000-1534264113_thumb.jpgpost-224-0-13580900-1534264122_thumb.jpgpost-224-0-37240100-1534264136_thumb.jpgpost-224-0-21469800-1534264129_thumb.jpgpost-224-0-37240100-1534264136_thumb.jpgpost-224-0-58874300-1534264753_thumb.jpgpost-224-0-24886400-1534264772_thumb.jpgpost-224-0-97737400-1534264780_thumb.jpgpost-224-0-33081900-1534264796_thumb.jpgpost-224-0-02393600-1534264807_thumb.jpgpost-224-0-89185500-1534264815_thumb.jpgpost-224-0-33057000-1534264826_thumb.jpgpost-224-0-91378600-1534264834_thumb.jpgpost-224-0-13608500-1534264844_thumb.jpgpost-224-0-47505200-1534264853_thumb.jpgpost-224-0-15474000-1534264861_thumb.jpgpost-224-0-58279600-1534264871_thumb.jpgpost-224-0-63753200-1534264883_thumb.jpgpost-224-0-26902100-1534264891_thumb.jpgpost-224-0-80641800-1534264901_thumb.jpgpost-224-0-05035200-1534264913_thumb.jpgpost-224-0-17293400-1534264922_thumb.jpg
https://www.facebook.com/andrei.eremia.98/media_set?set=a.108954149189588.18215.100002250093209&type=3
https://www.facebook.com/andrei.eremia.98/media_set?set=a.1139554299462896.1073741831.100002250093209&type=3
Hello Kalash and wellcome to our Skoda Forum.
This is exactly the right place to post, based on the cars that you own.
The second link does not open (maybe blocked for FB friends only).
The Skoda from the first link looks great. Congratulations for the effort put in it.
Where do you plan to cros the Stara Planina mountain, as some of the cross roads are better than others.
Pleasse feel wellcome to ask any questions, you may have about cars and routes in Bulgaria.
Regards,
Stanley
Редактирано от stanley
Regards,
Stanley
Hello ,
I have change the access to public .
The only access point in Bulgaria from Romania that make sens is Giurgiu-Ruse crossing point .
In order to the go on the highway (via Sofia) i must make a detour about 200 km .
My route in Bulgaria is the following Ruse - Veliko - Stara Zagora - Haskovo - Makaza.
Please feel free to five other routes if you think are better then the one i have choose .
Thank you
Редактирано от Kalash
The link is now available, thanks.
I was asking what is your route from Ruse to Makaza, because you have to cross Stara Planina mountain.
 the route i plan to cross Stara Planina is from Veliko to Gurkovo .
I just checked what are your options to cross the mountain:
1. The "Republica" cross road (also known as Hainboaz): Veliko Tarnovo - Gurkovo - good road condition, but too many trucks TIRs
2. The "Shipka" cross road - good road condition - mainly cars  - Veliko tarnovo - Gabrovo - Kazanlak - Stara zagora. You will see the "Shipka" monument - one of the biggest in Bulgaria. Built after the liberation of Bulgaria from the Otoman empyre in 1878.
The time and the kilometers are prety mutch the same. The Republika road is a bit shorter, but it has heavy traffic.
It is up to you to decide where you want to go.
Do not forget to buy a vignette after you get in Ruse. You can check the Shell or OMV gas station at the ring road of Ruse, after you get your way to Veliko Tarnovo. You can choose from weekly or monthly vignette. At the exit of Ruse near Metro store usually there is a Police car with a radar checking for speed violations and Vignettes.
Hello Andrei and welcome to Skoda club Bulgaria! Hope you will post photos of your trip to Greece and if need some help or advice we will be happy to help you. Congratulations for the great job done to both of your rear engined Skoda.  :plate_skoda:  :welcome_all:
thank you for the advice , in this case i think i will plan the route after Shipka cross road   :plate_skoda:
thank you , i hope that maybe in the near future we can organize a join meeting between our Skoda club's   :plate_skoda:
