Колеги, ЧНГ 2022 год. Много здраве и безаварийни км. да Ви спохождат.
Сега по същество. Притежавам Октавия 2,0 ТДИ с код на мотора CKFC. Закупих я преди месец . Направи ми впечатление, че лампата за подгрева не светва изобщо и днес я сканирах за грешки. При тест на таблото явно лампата са я премахнали, защото въобще не реагира /явно е мигала за грешки в мотора/
Грешките, които дава са:
Address 01: Engine (J623-CKFC)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 DT    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 5520
   Revision: 83H22---    CVN: 7F756533
   Coding: 111D0012032401090000
   Shop #: WSC 73430 031 00205
   ASAM Dataset: EV_ECM20TDI01104L906021DT 002004
   ROD: EV_ECM20TDI01104L906021DT_002.rod
   VCID: 7AEB901BC3F71D4301-802E
   VINID: 91D49A68779525500200508518C52D50C6
2 Faults Found:
7144 - Please Check DTC Memory in CAN Gateway (J533)
          U1008 00 [039] - -
          [Diagnostic interface for data busRead out DTC]
          Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 153548 km
                    Date: 2022.01.02
                    Time: 11:58:55
                    Engine RPM: 771.50 /min
                    Normed load value: 28.6 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 87 °C
                    Intake air temperature: 77 °C
                    Ambient air pressure: 970 mbar
                    Voltage terminal 30: 14.040 V
                    Unlearning counter according OBD: 40
                    Drivetrain coordinator: ACC fault status-Bits 0-7: 0
                    Drivetrain coordinator: brake fault status-Bits 0-7: 0
                    Drivetrain coordinator: brake function status-Bits 0-7: 0
                    Acceleration: 0.000 m/sІ
7158 - Please Check DTC Memory in CAN Gateway (J533)
          U1008 00 [039] - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 153548 km
                    Date: 2022.01.02
                    Time: 11:56:16
                    Engine RPM: 0.00 /min
                    Normed load value: 0.0 %
                    Voltage terminal 30: 12.220 V
                    Engine control module reset status-Bits 0-7: 0
                    Limitation: torque: 0.0 Nm
                    Limitation: accelerator pedal: 126.6 Nm
                    Cruise Control System (CCS): status-Bits 0-7: 0
                    Accelerator pedal travel: raw value: 0.00 %
                    Engine torque: -500.0 Nm
                    Generator: load signal: 30.00 %
Address 19: CAN Gateway (J533)       Labels:| 5Q0-907-530-V1.clb
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1164
   Revision: --------    Serial number: 0001822765
   Coding: 030100040F087300EF00064A1C0F00010001050000000000000000000000
   Shop #: WSC 73430 790 00205
   GVL: 01543C0000000000400C10000000C80000000000000000000000000000000000
   ASAM Dataset: EV_GatewLear 010015
   ROD: EV_GatewLear_010.rod
   VCID: 3FB406CAF78CBFA629-806A
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 5E0 919 719 B    HW: 5E0 919 719 B
   Component: E221__MFL-PR6  H04 0130
   Serial number: 000000000A0838120414
   Battery Monitoring Control Module:
   Subsystem 2 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
   Component: J367-BDMHella  H03 8043
   Serial number: 9056352703
1 Fault Found:
197149 - Generator
          U1052 00 [009] - No Communication
          [Generator (LIN#1) Timeout]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 61
                    Mileage: 153548 km
                    Date: 2022.01.02
                    Time: 11:57:58
                    Terminal 30 power supply: 13.7 V
                    Terminal 15: On
Останалите грешки се изтриха /е останаха грешки за датчик на ксенона и за навигацията, но съм поръчал датчик за нивото и нова антена за GPS/.
Очаквам помощта Ви за да вкараме колата в пътя. Явно няма комуникация между генератора и CAN шината и компютъра не може да управлява зареждането на AGM акумулатора. Четох по чужди форуми, но там нещата са да те пратят по-скоро в сервиз, а не да си намериш сам проблемите. Всякакви предложения са добре дошли. Не ми се иска да продам колата /и следващия регистрилал се тук да пише как да реши проблемите си/. Харесва ми и много искам да разреша казуса и да се наслаждавам на шофирането
може да провериш клемите на акумулатора, специално минус, както и връзката към купето (с разглабяне на връзката, почистване). Не звучи оптимистично, но е нещо.
Това е направено и не помага. Ще прозвъня кабела от клемата на - /виолетово-бял до синия на алтернатора/. Не мога да кодирам и акумулатора, защото няма BEM код, а е сменен с Банер.
Буквата със синия кабел беше откачена. Защо и с каква цел не мога да кажа. Генератора зареждаше AGM акумулатора с 14.2 в. След вкл. на буквата генератора даде 14.8 в. Дали са решени проблемите, ще видя след известно време. Остава като грешка старт/стоп системата.IMG_20220108_173445.thumb.jpg.e5b3cde71de26bd822c9e9d268f4e00b.jpg
толкова трябва да зарежда AGM може да е била откачена защото някога е бил използан обикновен акумулатор
