ремък или верига
beemaster
Replace spark plugs
Note To replace the spark plugs use the special spark plug wrench.
Observe the disposal instructions for the spark plugs.
Change interval: every 60 000 km or 4 years.
Tightening torque: 30 Nm.
Use assembly tool -T10029- for unplugging the spark plug connector (not applicable to cable with fixture).
Engine type/Engine identification characters Spark plug manufacturer's designation Parts No. Electrode spacing
(distance between earth electrode and spark plug insulator)
1.0 litre/37 kW NGK BKR 6ETA-10 101 000 065 AA 1.0 mm
1.2 ltr./40 kW AWY[/color] NGK PZFR5J-11 101 905 600 1.0 mm
NGK ZFR 5P-G 101 905 617 0.9 mm
BOSCH F7HER2 101 905 601 B 0.9 mm
BMD NGK ZFR 5P-G 101 905 617 0.9 mm
Brisk DOX 15 LE 101 905 618 0.9 mm
1.2 ltr./47 kW AZQ BOSCH F7HER2 101 905 601 B 0.9 mm
NGK ZFR5P-G 101 905 617 0.8 mm
BME BOSCH F7HER2 101 905 601 B 0.9 mm
1.4 ltr./44 kW Brisk DR 15 TC 101 000 060 AA 0.8 mm
1.4 ltr./50 kW Champion RC-89 PYC 101 000 049 AC 0.8 mm
1.4 ltr./55 kW AUA, BBY NGK BKUR 6ET-10 101 000 033 AA 1.0 mm
BKY BERU 14F-7 HUR 2 101 905 603 B 1.0 mm
1.4 ltr./59 kW BOSCH F7HER02 101 905 601 F 1+0.1 mm
1.4 ltr./74 kW NGK BKUR 6ET-10 101 000 033 AA 1.0 mm
2.0 ltr./85 kW NGK BKUR 6ET-10 101 000 033 AA 1.0 mm
