откачен ремък
marion
Вчера по време на движение чух едно свистене светна и сигнала за акумулатор.Спрях и се оказа изцяло откачен ремък също откачен бе и целият механизъм на опъвателната ролка .Как мога да оправя повредата сам ?
Не знам.
П.С. Все пак има Фабия 1 и 2, различни двигатели, как да ти дам отговор?
Не знам.
Аз те разбах ама явно други не те разбират smile091
След уточнения, колата е като твоята Fabia I 1.9 SDI, 2006 с климатик.
Summary of components - Vehicles with air conditioning
Note: Mark the rotation direction before removing the V-ribbed belt. Reversing the rotation direction of an already used belt may destroy it.
Pay attention to the correct position of the V-ribbed belt in the belt pulley when installing it.
1 - 10 Nm + torque a further 1/4 turn (90°)
2 - Vibration damper/belt pulley
Assembly only possible in one position - holes offset
3 - 25 Nm
4 - Generator
to facilitate the positioning of the generator on the holder drive the threaded bushings of the retaining screws slightly backwards
5 - Tensioner for V-ribbed belt
6 - Bracket
for injection pump, generator and AC compressor
Dowel sleeve for centering → Fig.
7 - 45 Nm
8 - AC compressor
9 - Dowel sleeves for AC compressor
q must be present in holder → Item
10 - V-ribbed belt
Removing- vehicles with air conditioning
– Remove noise insulation -arrows-.
– Mark the rotation direction of the V-ribbed belt.
– To slacken the V-ribbed belt turn the tensioning device in the direction of the arrow.
– Removing the V-ribbed belt.
Installing
Note check V-ribbed belt for wear → Booklet Fabia.
Before fitting the ribbed V-belt make sure that all assemblies (generator and AC compressor) are securely mounted.
Check smooth operation of belt pulley and tensioning pulley.
– Tighten the tensioning device in the same way as when removing and fit ribbed V-belt
3 - 25 Nm
4 - Generator
6 - Bracket
7 - 45 Nm
8 - AC compressor
10 - V-ribbed belt
[attachment=2]S13-0361.png[/attachment]
[attachment=1]S10-0114.png[/attachment]
[attachment=0]S13-0222.png[/attachment]
Installing
Благодаря за чертежа но ще бъде трудно да стигна до болт 3 той е останал вътре .
Нямаш работа при болт 3. Цялата работа се прави само от ролката от последната схема. За да падне ремъка нещо е блокирало и трябва да провериш кое е.
Той казва че го няма целия механизъм ако съм разбрал правилно за което иде реч че се е скъсал болта които го държи за блока. Хем преди 2 дена си смених ангренажа и не забелязах как точно се държи този механизъм но ако е на болтове и са се скъсали единствения начин е с обратен метчик да се опиташ да развиеш болта или пробиване и навиване на нова резба. Не искам да те подвеждам само предполагам какво и как е станало
И на мен ми сви Фабията 1.4 16V 101к.с. подобен номер на 50х км.Слизам,гледам ремъка на земята.Сложих го и си продължих безпроблемно.Така и не разбрах от какво се получи.Само че при мен освен ремъка всичко друго си беше на мястото.
Подкрепям мнението на gedore.На мен ми се случи два пъти за 5000 км и докато не смених ролката на алтернатора , не се оправи.Тези ролки трябва да се сменят заедно с опъващата ролка и ремъка.Иначе ще ви падне ремъка неочаквано, може на някоя нива....
И при мен снощи се получи подобен проблем, по време на движение изведнъж светна червената лампа на арматурното табло с акумулатор, като спрях установих, че обтягащата ролка на пистовия ремъксе е отчупила от конзолата си и е паднала върху кората под двигателя, ремъка също разбира се, но не скъсан.
Темата е изкючително полезна и бих искал да попитам, ролката на алтернатора задължително ли трябра да се смени /с пръсти не се усещат никакви хлабини по време на хода й/? Ако трябва по какъв начин се сваля?
Обтягащата ролка само на болт номер 3 от горепосочената схема ли се държи и кората под двигателя ли се свали за да се отвърти, защото първия ми опит да го отвия се провали заради липса на пространство за работа отгоре, а и удължението на тресчотката, която имам попада точно на пътя на щеката за нивото на маслото?
Поздрави и Весели празници!
ако е блокирала- задължително
Ако няма нищо специално при установяване на това дали ролката на алтернатора е блокирала или не, мисля че не,а и се движи без никакво усилие и с равномерен ход.
ме мисля ,че сам можеш да установиш дали е блокирала
трябва оста на динамото да може да се движи свободно само по часовниковата стрелка,когато ролката е в покой-тоес я задържаш или с двигатела или с ръка ако си без ремък
